Tire wear
Old Apr 14, 2007 | 06:00 PM
Hereigns's Avatar
Default Tire wear
My 2 year old Mazda 3 has gone through 5 sets of tires. The latest set is wearing out from the inside out. Alignment was done today (with one 5 month old tire replaced). I checked for tsb's and recalls, but there are none...I no longer buy the $200 high performance tire but the $134 everyday tire instead. Is that the issue or is there something else wrong?
Old Apr 14, 2007 | 08:35 PM
UrbanmanUSA's Avatar
Default RE: Tire wear
ORIGINAL: Hereigns
1. How many miles are you getting out of a set of tires? Most tires have a mileage warranty, if they wear out faster than the warranty,with normal driving, you should be able to make a claim.
2. Do you drive nascar style?
3. Anything really unusual about where you drive?
Old Apr 14, 2007 | 10:47 PM
sstlaure's Avatar
What kind of wear patterns are you seeing on the tires?
FYI...High performance tires do wear faster.
If you want something that lasts a decent length of time, look for something with a wear rating of 300 or higher. I got 42,000 miles out of my last set of Toyo Proxes FZ4 (wear rating 300)
Old Aug 13, 2008 | 06:56 PM
todd.davis's Avatar
I am having a similar problem. 56K miles and I am putting my 3rd set of tires on the car. Uneven wear on the last set on inside tread. Alignment check says car is in alignment. I plan to call the dealer after finding some info here first. I have the 205 50 17s. The goodyears were okay, the Kumho exsta was better but short lived. Now I am trying the Falken 452.
Does this car require rear alignment?
Just noticed the dates on this thread- oops.
Old Aug 13, 2008 | 10:01 PM
ORIGINAL: todd.davis
... Just noticed the dates on this thread- oops.
That's OK Todd.
Your shop issaying the alignment is"in-spec." I personally find that much neg camber to be a little excessive and cause irregular rear wear. If your car is lowered, that will add to that. I would ask them to pull out as much neg camber as they can.Regular rotations front to rear will help.
Old Aug 14, 2008 | 01:49 PM
1funride's Avatar
ORIGINAL: Hereigns
Looks like your still in your Warranty period. You may want to take it to the dealer to find out whats going on. I have a11 monthold MS3 with 6,600 miles on it with no tire issues.
frostyhouse
Mar 30, 2010 10:02 AM
radiologypa1971
May 5, 2008 10:50 AM
mgk1068
Jul 22, 2007 11:00 AM
LVMYWLVS
Jun 15, 2007 04:19 PM
kirkie
Jun 19, 2006 08:38 PM
