Skyactiv - AFS OFF unable to turn back on
Old May 19, 2018 | 03:25 AM
Fragden's Avatar
Default Skyactiv - AFS OFF unable to turn back on
Hi all,
The other day I took out the throttle body to give it a clean. After plug back everything I turn on the engine but was given a check engine light. I took a look at the assembly and everything was fixed back correctly. So I disconnected the negative terminal to reset it a bit. Plugged in and started engine with no check engine light. But the AFS off stayed on.
I took it to mazda service ctr but they are unable to reset the thing. They said probably the lighting system got shorted somewhere and they are unable to determine.
can somebody help? What can I do to fix this on my own? It should be minor fix unless I really shorted something when fixing back the battery negative terminal...
Old May 19, 2018 | 03:59 AM
Mazda should of hooked up their scan tool & found a fault code for the AFS.
Without knowing the fault code, you're stabbing in the dark.
Try disconnecting the battery overnite, reconnect it & try your luck.
Old May 19, 2018 | 08:53 PM
Fragden's Avatar
Tried that mate and it's still there.
i guess the code reader does not point to exact location fault.
is there a fuse for the AFS?
Nicole Snodgrass
Mar 19, 2018 02:03 PM
j412
Jul 10, 2017 06:30 AM
howardstevens
Oct 31, 2015 01:20 PM
JDD1978
Dec 9, 2011 12:19 PM
gregno
Feb 27, 2008 04:46 PM
