Rear power window problem
Old Feb 24, 2019 | 07:52 PM
bboyukoy's Avatar
Default Rear power window problem
Hi.
My car’s rear power window won’t go down or open if I use the control or button on the driver’s side. I don’t know what’s the name but on the driver’s side, it used to work. It closes (going up) but it won’t open. If I use the control on the rear passenger side, it works; it opens and closes. I can open the window on front passenger side but not both rear windows. Front driver’s window works fine.
What could be the problem?
Old Feb 25, 2019 | 03:08 AM
If the window goes up & down using the switch on the actual door, but not via the drives master switch, then the fault is 99% with the drivers master switch.
Old Feb 25, 2019 | 10:01 PM
bboyukoy's Avatar
Do you think spraying contact cleaner on main switch helps?
Old Feb 27, 2019 | 05:45 AM
Wouldn't hurt to try.
Old May 24, 2020 | 09:20 PM
minotauris727's Avatar
Originally Posted by bboyukoy
Hi.
I'm having the exact same issue with my rear driver's side window. Works fine from local switch. Will close from driver's control switch, but not open. Where you able to resolve this issue?
Old Aug 27, 2023 | 04:31 AM
bboyukoy's Avatar
Unfortunately no. I have opened the switch from the driver's side but I don't have that tiny screw. I don't know what it's called but the screw has so many points. I saw a video on YouTube and it's quite easy to follow. So I haven't fixed mine.
Sorry for the very late reply. There's no auto email for replies. Maybe it's not in the mobile view of this forum since I am usually using a mobile phone
jhendren
Sep 28, 2022 01:55 AM
1993 Mazda 323 BC Guy
Oct 19, 2016 02:49 AM
HerrKaLeun
Aug 4, 2013 08:34 PM
rubyfan
Jun 20, 2007 10:45 AM
needforSPEED6
Sep 27, 2006 10:50 AM
