Rear power window problem
Hi. My car’s rear power window won’t go down or open if I use the control or button on the driver’s side. I don’t know what’s the name but on the driver’s side, it used to work. It closes (going up) but it won’t open. If I use the control on the rear passenger side, it works; it opens and closes. I can open the window on front passenger side but not both rear windows. Front driver’s window works fine. What could be the problem? |
If the window goes up & down using the switch on the actual door, but not via the drives master switch, then the fault is 99% with the drivers master switch.
(Post 173204)
Wouldn't hurt to try.
Originally Posted by bboyukoy
(Post 173194)
Originally Posted by minotauris727
(Post 183686)
I'm having the exact same issue with my rear driver's side window. Works fine from local switch. Will close from driver's control switch, but not open. Where you able to resolve this issue?
Sorry for the very late reply. There's no auto email for replies. Maybe it's not in the mobile view of this forum since I am usually using a mobile phone |
