Mazda 3 2010 ABS C0034 Code
Hello, my Mazda 3 2010 Hatchback has an ABS light on and the code my OBDII Scanner gives is C0034, and it says theres a problem with the Front Right Wheel Speed Sensor.
I changed the Front Right Sensor and checked if the connection has power and it does, but I am unsure of what else to check. Could it be a bad wire going to the ABS module?
Thank you!
Thank you!
