Mazda 3 2.2D skyactiv - Coolant loss
Old Nov 1, 2022 | 12:47 PM
Christian89's Avatar
Default Mazda 3 2.2D skyactiv - Coolant loss
Hi,
I purchased an early 2016 Mazda 2.2D skyactiv with 72000 miles on it from a garage about three weeks ago. A week after buying it I noticed the coolant was lower than it should be. Bought some Fl 22 coolant an topped it up to the max line. I then took it to a garage to check it out and they said no leaks. Two weeks later and the coolant has gone from maximum to minimum again, with no temperature warnings etc.
I just used a test kit off Amazon to check for exhaust gases in the coolant and there wasn’t a change in colour. There’s no other typical head gasket symptoms present as far as I can tell. What else could it be?
Regards
Christian
Old Jul 9, 2024 | 02:36 PM
AlexSandu's Avatar
Originally Posted by Christian89
Hi,
Regards
Christian
Hi,did you manage to find out what was the problem?
I have kind of the same issue,just in addition it smokes and smells bad,but not sure if it's related to the coolant loss.
Firstly when bought the car i blamed the radiator,i changed it but it didn't help.
Steve Parker
Apr 22, 2021 09:13 AM
rtaylor
Mar 22, 2021 08:44 AM
rlb
Jun 24, 2014 02:16 PM
bozanbo87
Nov 5, 2009 05:43 PM
mazda guy
Nov 12, 2005 03:33 AM
