code po704
Old Jan 22, 2016 | 05:53 PM
mannyf 73's Avatar
Default code po704
Hi I have a mazda3 05 with code po704 any info will be appreciated
Old Jan 23, 2016 | 06:10 AM
P0704 is the Clutch Pedal Position Sensor.
You may be able to bridge the terminals on the connector to test if its the switch/sensor at fault & not a wiring issue.
Worst case scenario is a faulty PCM.
Old Jan 23, 2016 | 01:32 PM
mannyf 73's Avatar
Thanks I'll let you know what I come up with
Old Jan 24, 2016 | 01:11 AM
thzpcs's Avatar
Does the car still start okay? I've had a car that had this go bad, and it wouldn't start as it couldn't detect the clutch being pushed in for it to start.
Baston-Rob
Dec 25, 2011 04:48 PM
Bobbygian
Sep 30, 2010 09:07 AM
