Clicking noise coming from under the steering wheel.
Old Sep 28, 2020 | 10:42 PM
Bcngl's Avatar
Default Clicking noise coming from under the steering wheel.
Hey guys,
There is a clicking noise coming from under the steering wheel of my 2018 Mazda 3. I'm not sure about other people's Mazda but my car has this electronic click sound everytime it travels the first 50 meters after starting and the sound disappears. The "starting" click sound has always been there since the day I picked my car up from the dealer and my previous 2014 Mazda 2 had it too.
But these past 2 days the click sound comes up during my drive and it has been driving me insane. It only clicks when the car is being driven but not when it is stationary.
Luckily I recorded the sound during my drive. Here is the sound of the said click during my drive:
Has anybody ever experienced this? If so, what was the problem? Is it a bad relay or anything else?
I appreciate the help. Thank you.
Old Dec 29, 2020 | 02:05 AM
Tyler Little's Avatar
My 2010 Mazda CX 7 just started making this noise exactly identical to yours. The sound is coming from under the steering wheel but the twist is, it causes my headlights to flicker and only does it between 50-20km I can get it to stop by pressing the brake pedal enough to turn on the brake lights and it stops as soon as I take my foot off the brake noise comes back if I put my foot on the gas noise goes away if I take my foot off the gas and let the car coast it will make the damn noise again ARGHH!
Old Dec 29, 2020 | 07:17 PM
Update from my cx 7 it appears the noise in your car and mine is related to the ABS and Traction control system. Im not 100% sure but it sounds like it could be the cause When I was driving today it clicked in the same rythhm as your video described. But for some strange reason the ABS and Traction control lights came on in the dash and the clicking noise stopped... when I turned off the car and restarted it the lights went out and the noise returned. But I don't know what part of the system is causing this problem
Old Jan 16, 2021 | 03:05 PM
winkybil's Avatar
Check the strut. Sounds like the spring broke. They bind and pop as you turn. The newest VW I've changed struts on broke the top coil off so it was kinda hard to see without lifting the car. You might be able to see the spring jump if you turn with the wheel on the ground.
Kodi nox
Old Jan 16, 2021 | 09:49 PM
If the noise only happens once, soon after starting the car and driving off, its a good chance its the ABS module doing its self test.
Old Jun 27, 2021 | 05:34 PM
Bcngl's Avatar
Sometimes it happened when the car is driving. When I put it in neutral the sound goes away, when I shift the car to Drive and I push the throttle the noise starts clicking again.
Isn't ABS module located in the engine bay?
Old Sep 26, 2021 | 10:15 PM
Brocktt's Avatar
I looked at them and didn't see anything wrong with them I will check again, do they also make noise going in a strait line though?
Old Sep 26, 2021 | 10:17 PM
Brocktt's Avatar
yes it is in the engine bay it looks like block of metal with metal hoses coming out of it.
jwallis
Mar 21, 2020 12:16 AM
andromeda
Apr 24, 2018 10:29 PM
AntiRiceDevice1
Feb 4, 2013 05:25 AM
devasta
Feb 16, 2009 10:28 AM
bhoyler
Jan 7, 2008 09:07 PM
