2013 Mazda 3 Transmission Pan Torque Specs
Old Jul 30, 2021 | 01:39 PM
prenger745's Avatar
Default 2013 Mazda 3 Transmission Pan Torque Specs
I am looking for the torque specs for the transmission pan bolts of a 2013 Mazda 3 Sedan. Specifically: 2013 Mazda Mazda3 i 4 Cylinders F 2.0L FI DOHC 122 CID
If there is a full manual out there somewhere, I would like to have that as well!
Thanks,
Danno
Old Jul 31, 2021 | 01:31 AM
8-10nm
Old Jul 31, 2021 | 10:06 AM
8-10nm
This is also I believe without a gasket? If you choose to use a gasket (unless it is factory specified) instead of sealer only then you must snug the bolts , let the transmission get to operating temperature and then re-snug them. Over tightening gaskets can cause them to be pressed out from there sealing area not normally designed for a gasket and cause an eventual leak.
Because this meaning "SNUG" is different depending on what country it is used.. LOL
SNUG= a way of saying they're feeling a little tight (for a fastener use common sence and not a [size=13px]gorillas[/size] approach to tightening)
8-10nm = 70.806 -88.5075 in-lb
Old Aug 5, 2021 | 10:43 AM
prenger745's Avatar
@Callisto This WILL be with a gasket. I would like to tighten them a little more precisely than "snug". Would 6nm be too much? Or is there a spec out there for that?
Thanks!
Old Aug 5, 2021 | 12:09 PM
Thanks!
Unless the company you purchased the gasket from i.e. Fel-pro, Mccord,etc., and they give recommendation for torques specifications and unless there is listed OE MAZDA a pan gasket then you can go by torques specification, you are changing the engineered design for a none gasket area and there is no real torques values so you need it "SNUG" up and recheck to prevent leaks as I suggested making sure a good seal without bending or distorting to shape of the pans flange which would likely cause it to leak.
All fasteners have a torque value depending on what grade they are and how they are being used. The exception is in your example that the area may not have come with a gasket and now you are using one.
To be sure so we understand that I am giving generalized information about uses a gasket in an area that did not come factory with a gasket, I did not look at your exact model year and see what it came factory MAZDA with or without a pan gasket.
Neanderthal
Apr 25, 2020 03:48 AM
gordie1969
Nov 29, 2017 07:22 AM
McMazda
Mar 17, 2017 04:34 AM
leatag
Detailing
Feb 5, 2013 04:57 PM
lostjr
Oct 17, 2012 01:58 PM
