2012 Mazda cruise control
Thanks--I have read other places and I agree with you. I think the thing called the ecu has to be turned on to allow the cruise to work. I have obtained the wiring diagram for the 2012 and they only use one wiring harness. Every thing should be there. Drove the car last night and all the lights work fine.
OK everyone. Just had my Mazda 3 I-sport put on the computer this afternoon and had the speed control setting turned on. The service rep tried to tell me the car did not have the necessary stuff to work but I convinced him to try it. I told him I would pay for the work even if it did not work. He was shocked because he had been convinced that it wouldn't. It worked like a charm. He plugged his computer in to the under-the-dash port and fired up his diagnostic program and selected the VIN number and then selected the speed icon and hit enter and the computer told him to select inhibit or activate. He punched activate and the program ran for about a minute and then said done. He disconnected and drove around the block and came back with a big grin and said that I now had cruise control. Cost me $27.00 bucks for the job. DON'T LET ANY DEALERSHIP TELL YOU IT CAN'T BE DONE. The only part you need is the switch assembly Mazda part number BBM5-66-4M0C. The "C" indicated that it is for a 2012 model. You can get the part here markk@northpennvwmazda.com . Cost $178.00 plus shipping. Mark can be reached at mazdapartswholesale.com. The steering wheel/switch removal and installation guide located on this web site is simple and very easy to do. I left my positive terminal cable off all night with the light switch on just to be safe.
Mine is the 5 speed automatic/manual. Based on everything that I have read it makes no difference on the cruise control. Not sure though. The brake switch is the same on all the 2012's. The swith number is BN7N. It is very easy to remove and look at it. The BN7N cost $14.00 if you need it.
I just read the advertisements. "They tell me it's automatic/manual I believe it." I once had a 1968 VW that had no clutch but the tranny was the same as the ones that had a clutch. I believe they called it an electric clutch. (no pedel)
