2009 Mazda3 MPS BL - Keyless push start, central locking, radio, dead battery
Old Jan 4, 2021 | 01:07 AM
574CEY's Avatar
Exclamation 2009 Mazda3 MPS BL - Keyless push start, central locking, radio, dead battery
Hello
I have a 2009 Mazda 3 MPS BL. I have a few issues happening with my car now that the battery had died and I have replaced the battery.
1. I have recently changed the battery in the car as the other one died. I tried to start up my Mazda using the keyless key (which always used to work) and is now working. When I push in the clutch to start, it does not even recognise the keyless key (for both of my keys). I tried to put the key straight into the ignition but the push start button illuminated red. The central locking does not work either. I have a 3rd key which is the one I got when I purchased the car 7 years ago, although that does not have the keyless cover. The key works and starts my car up just fine.
2. Drivers window doesn't automatically go down. I have to hold the button for the window to come all the way down (this never use to be the case).
3. The Revs stays on 1 when I turn my car off instead of going back to 0.
4. The radio doesn't work. Matter of fact, none of the buttons to the radio/ CD play/ AUX/ Bluetooth etc work. There is nothing on the top part of the screen...
I would love your help with any of the above problems.
Thanks!
Old Jan 4, 2021 | 04:42 AM
1): 1st step would be to disconnect the battery, wait 5 minutes. Make sure all the doors are closed & lights off, reconnect battery and see what happens.
2): Re window, hold the button all the way down, then hold it all the way up & wait 2 seconds before releasing switch.
3):Re revs, hope fully battery disconnect will fix it.
4): check room fuse and both audio fuses.
Old Sep 17, 2021 | 07:08 AM
joemoore23's Avatar
Did you fix this? I’m the same
jpmyers15
Dec 16, 2020 08:34 PM
Bonialam119
May 18, 2020 05:49 AM
mazdanovice2020
May 9, 2020 01:46 PM
RF1Triker
Dec 30, 2018 11:42 AM
yogadoc
Jan 2, 2016 05:25 PM
