Radio out.
Old Sep 9, 2021 | 01:23 PM
unclebobg's Avatar
Default Radio out.
2014 Mazda 3. Standard (Type A) radio.
Battery was bad. Daughter jumped incorrectly, reversed polarity. I have replaced battery. Everything works properly except the radio (entertainment system). Will not power on. I checked all fuses on the car and don’t see any that failed.
Any suggestions? Thanks.
Old Sep 10, 2021 | 11:54 AM
Mazdaon's Avatar
Are you referring Type A as the audio system without center display? There are major 4 fuses: Cabin, Room, Audio1, Audio2 and Bose if fitted. Also have you check fuses for ACC and their Relays?
You need to pull system and confirm +12V right up in the terminals if they are present most likely the system got fried, check Ebay for a replacement.
I leave the Service Manual Here
Old Sep 10, 2021 | 03:36 PM
unclebobg's Avatar
Thank you very much for the info and the manual.
Old Sep 17, 2021 | 11:09 AM
Mazdaon's Avatar
Why are you creating a new thread or are you having another issue?
What kind of audio system do you have ? Have you check for presence of 12V at pins 1R and 1B in audio system without center display? or pins 2Q 2R with display.
Old Sep 17, 2021 | 01:00 PM
unclebobg's Avatar
I will do that. Meanwhile, why is it so hard to tell me what relay/relays are involved? As to radio type, it is the unit described in the 2014 Mazda 3 manual as “Type A,” which is the one with the small display above the dash and no actual video screen.
I am a home mechanic without any electronics knowledge, so sometimes I need a little more information.
Thanks.
Jurgis Funts
Jan 15, 2021 04:50 PM
Ricks02
May 6, 2020 01:31 PM
Larry L
May 5, 2017 02:47 PM
wlsn_tmm@yahoo.com
Mar 5, 2016 01:09 AM
jammer
Apr 15, 2011 05:34 PM
