Mazda 2 knocking steering
Old Jan 5, 2022 | 03:37 PM
the_bart123's Avatar
Default Mazda 2 knocking steering
Hi everyone.
I've tried to search same problem here in this forum but I cannot see anything.
I got widely known Mazda 2 2011 knocking/clunky steering.
Any chance to point me which part is exactly faulty/worn? Is it that electric steering engine or just shaft?
If just shaft - is it possible to replace it from just top (inside cabin) without lifting car?
Because it is hard to find replacement part in UK - how does it looks like and can I for replacement for Ford Fiesta 2011 too?
Is replacing this part looks like here (I know it might not be Mazda 2 2011)
Thank you in advance
Old Jan 6, 2022 | 02:31 AM
Super common problem. Must of fixed a hundred of them.
Remove the lower column shaft. Mark the two sliding pieces, drill out the dowels/pins, pull it apart, clean it, lube it up with Magical Orange Mazda grease, reassemble. Fixed.
Same principle as the Mazda 6 fix. That video is very amateurish & concerning.
Old Jan 6, 2022 | 12:59 PM
so that grease is not just temporary fix?
Is not metal worn / loose on that thread to joint two shafts together?
It started to happening to me about 20.000 miles ago - MOT guy said no loose front wheels.
Will something bad happen if I will drive like that for another 20.000 miles - because I do not care about knocking?
Thank you for helping me.
Old Jan 7, 2022 | 04:37 AM
It's amazing the horrendous noises I heard from these cars, only to be fixed by lubing the steering shaft splines.
I can't see into the future, I wouldn't recommend ignoring it.
Eli Sasonov
Jun 22, 2020 12:21 PM
Cinque_Terre
Oct 24, 2019 12:33 PM
alxmanns
Jan 29, 2017 05:37 AM
samjac68
Jul 1, 2011 06:19 AM
billhendley
Jan 16, 2007 08:11 PM
