MAZDA 2 DE 1.3lt ZJ-VE Engine Disassembly
Old Jan 18, 2026 | 03:30 AM
OZCorolla_x2's Avatar
Smile MAZDA 2 DE 1.3lt ZJ-VE Engine Disassembly
Had been looking for a MAZDA 2 DE 1_5lt MZR ZY-VE Engine Disassembly Video
Found this one for a MAZDA 2 DE 1.3lt ZJ-VE...very similar
youtube.com/watch?v=ihZ3cNHjOl0
Successful Mazda 1.3 MZR engine (ZJ-VE). Why aren't all motors so reliable? Subtitles!
Jan 23, 2021
& its video/picture quality is good.
...Republic of Belarus so subtitles & the "Transcript English Auto generated text" is not perfect...
If you have the MAZDA 2 DE 1_5lt MZR ZY-VE Engine Workshop Manual, it is VERY Useful
Start watching at:
@1:06 1.3lt MZR (ZJ-VE) - discusses rough idle
@3:27 Engine Disassembly Commences
@ 10:35 Clear view of the Underside of the Head on the Display Table
Water Jacket pass through the Block locations V’s Cylinder Wall Clearance looks Ok
This is some of the BEST Video I have seen of this during disassembly & something I was looking for
The internals of the one above looks substantially better than this one.
youtube.com/watch?v=B2mxncQsaXo
Cam Cover Off @1:54
@2:03...Bits
etc
youtube.com/watch?v=-MFPaAwXH38
Part 2
@2:01 lots of...
@2:32 ahhh
@2:58 Piston out
@3:10 PCV Return Baffles
@3:26 the recover process
Hope the above helps someone/is of interest.
Rob
Old Apr 22, 2026 | 04:05 PM
ThomasHall's Avatar
Good finds, especially that first teardown of the Mazda MZR ZJ-VE engine—it’s actually one of the better visual breakdowns I’ve seen too, mainly because it shows the block, water jacket, and head condition clearly instead of just rushing through disassembly. What you’re noticing about the internals is typical: these ZJ-VE motors tend to look surprisingly clean if they’ve had decent oil changes, while the rougher examples in other videos usually show sludge around the cams and PCV return areas. The 1.5 ZY-VE is similar in layout but a bit more prone to wear issues when maintenance is skipped. Overall, those videos are useful because they make it easier to understand where the common failure points actually are rather than just guessing from symptoms.
ondersma80
Feb 18, 2024 08:58 AM
IamFODI
Jan 5, 2024 04:40 PM
trahnagrom
Aug 2, 2020 02:27 PM
keninn
Apr 7, 2014 05:50 PM
UseYourNoggin
Oct 10, 2012 10:04 AM
