EGR valve hose
EGR valve hose
I have a 2001 Tribute V-6
the small rubber vacuum hose connected to the top of the EGR valve is cracked, brittle, and dried out and is causing a p401 code (insufficient EGR flow)
the engine is running fine but I'd like to correct the problem
I thought it would be an easy fix just to replace the rubber hose, but the dealer only sells the hose as part of a set of connected hoses with connections to the entire EGR system. A photo of it is below. The hose I'm talking about is the one in the center of the picture with the elbow connection at the end.
Has anyone done a DIY fix for this hose?
