05 tribute 2.3 engine removal w/o manual tranny
Old Aug 28, 2018 | 10:13 PM
Bob Howell's Avatar
Default 05 tribute 2.3 engine removal w/o manual tranny
20005 tribute 4wd 2.3l w manual transmission
Engine seized up on the highway
I would like to remove the engine without the clutch and transmission. Is this possible? I can't turn the engine over due to it being seized. I guess I can dropped the pan and find it why it wont turn over. And disconnect the rod to get it to turn over.
Anyone have a step by step or service manual that would help? I found a 2006 escape motor 2.3 that I plan to drop in once it is pulled.
Any advice would be helpful.
Thanks
Old Aug 29, 2018 | 06:07 PM
simonsi's Avatar
The clutch will come out with the engine as it is bolted to the engine flywheel. TBH I'd pull them assembled and split afterwards - the Haynes manual details the procedure I think (mine is at home at the moment).
Engines seize due to overheat or lack of oil, you need to know what caused yours otherwise if it a cooling issue or oil cooler leak you could just toast the new motor. Exactly which bit of the engine is seized now is probably less relevant unless you intended to rebuild it.
rspi
Jul 1, 2013 09:28 PM
b6t323
Mar 28, 2013 12:10 PM
mriley1045
Jun 30, 2008 03:41 AM
brokempv
Mar 5, 2008 01:08 AM
mazdab2600
Nov 29, 2006 11:22 PM
