2002 Mazda running horrible
I will as soon as I can get my hands on the scanner again. I really appreciate all your insight!
LOL if you checked the monitors that would have reviled things. But a problematic CAT would have generated at least one of several DTC none that you posted. And then there is the obvious. rotten egg smell and change in the exhaust tone. The other test would have been to run the engine to operating temperature and measured the Hc's at the exhaust or what the EGT and CAT temperatures were. However and again nothing you posted has pointed to a failed or failing CAT.
[QUOTE=Callisto;239442]LOL if you checked the monitors that would have reviled things. But a problematic CAT would have generated at least one of several DTC none that you posted. And then there is the obvious. rotten egg smell and change in the exhaust tone. The other test would have been to run the engine to operating temperature and measured the Hc's at the exhaust or what the EGT and CAT temperatures were. However and again nothing you posted has pointed to a failed or failing CAT.[/QUOTE
hey sir what specific monitors am I looking for. You say to check IM monitors but I’m not sure what that is. I have forscan. Will that show me what you’d like to me check? Thanks
