A/C Compressor cuts out
Old Aug 17, 2008 | 08:58 PM
04nordicgreenrx8's Avatar
Default A/C Compressor cuts out
Hello,
I have an '04 RX8 6-Speed with 38K miles.
I am having a situation where my A/C compressor seems to cut out randomly. I will have no problems for 1 week, then one day when I start the car the compressor does not run and I am blowing hot air! The next time I start the car (later in the day), the compressor is working fine and blowing cold air again. This is not a freon issue, since I would expect to have a drop over time on the cooling - not this on/off issue.
Has anyone experienced this? I am currently out-of-warrenty, so I know that bringing this issue in for service will cost me.
Regards, Rob
Old Aug 18, 2008 | 10:30 PM
Froggman's Avatar
Default RE: A/C Compressor cuts out
Rob,
This sounds like you have a bad pressure switch. Look under you'r hood for the accumulator/reciver dryier, The switch will be mounted to it and have a electrical plug on it. You can buy one at any parts place. You can remove it and not loose any freon and screw the new one in place of the old one. In fact you can do it right at the parts house.
Old Aug 19, 2008 | 08:51 AM
Mazmart Trini's Avatar
ORIGINAL: Froggman
Rob,
Actually, you are wrong. He will lose freon. It needs to be taken to a shop that is licensed to do AC systems to have it done properly.
Old Aug 19, 2008 | 07:53 PM
Hello,
Someone indicated that I try making sure the temperature gauge is all the way on cold, and give it a little nudge past where it normally stops.
I tried that and it works! Does anyone know about this, and what should be done to permanently fix this? Should Ireplace theknob/dial as a result of this? Or is there a way to make an adjustment to the ****/dial to correct the problem?
Old Aug 20, 2008 | 07:48 AM
You may have a bad A/C & Heater Control. Not unheard of in the RX8 community.
Jer
May 15, 2007 05:00 PM
derekmazda6
May 10, 2007 12:49 PM
theguy
Jan 28, 2007 04:27 AM
austinengineer
Dec 13, 2005 01:26 PM
coaky
Sep 13, 2005 05:35 AM
