89 626 cuts out, stalls, no restart. Help plz
I was on the interstate when the car started cutting out, when I got to a stop light, it died while starting to accelerate on green. It wouldn't start back up immediately. I waited a few minutes, tried it again and it started. Got to where I was going, then it died in the parking lot, immediately restarted though, so I cut it off and went in for a couple hours. When I came back out, all it would do is crank, it was turning the engine, but wouldn't start. It never backfired. I had just gotten a full tank of 87 octane gas from a place where I don't get gas much a few days earlier. Had to have it towed to my house. The first time I tried it, it started, ran a while at a rather weak idle, then died and would start again until the next day. The first thing I replaced was the fuel filter, it seemed to be really clogged when I blew through it, took all my lung power, whereas the new one just whistled. The new one made no difference though, so I replaced the ignition coil, then the distributor cap and rotor, then the battery, plugs, and plug wires. Nothing has made a difference. This car has always run strong and I can't figure it out. Oh and when it does run and I rev it, it produces a lot of white smoke. I'm not totally sure on this part, but it seems that when it was cutting out on the interstate the tach was falling each time. I've read that it could be the distributor, or the fuel pump, or bad gas. Can anyone help?
my 86 mazda 626 has all the same symthoms even the smoke. its sitting dead in my driveway and its the only car i have. im waiting for one the forums readers to help me with some of the vast knowledge? if i hear of anything i will post for you and if you hear anything post for me thanks and good luck. a little help please thanks and happy new years to you all tedjames
could be lots of things honestly, not sure if that has the egr, map, or tps sensor but if it does I'd check those first. being there is smoke involved you may have blown a gasket as well. what did the plug look like when you pulled them? is there a high pitch whistle sond when it's running coming from around wehre the fuel pump is?
Hi guys.... hmmm.... white smoke.... that's definitly not a good sign....usually indicates coolant is leaking into the cylinder..... which means a blown head gasket or cracked cylinder head.
Either problem (gasket or head) would cause very poor running conditions.
It's not a simple fix unless you are an accomplished do it yourself kind of person....
Unfortunatly I don't know of an easy way to diagnosethis issue with 100% certainty... and head work isn't cheap.
Any way you cut it.... white smoke means coolant..... black is too much fuel.... blue is oil.
pieman1uk
Jul 1, 2013 10:03 PM
sandeshraj83
Mar 31, 2009 01:55 PM
MAYz4
Aug 2, 2006 04:32 AM
