washer fluid pump/connectors?
Old Aug 19, 2006 | 01:12 PM
mazdadad's Avatar
Default washer fluid pump/connectors?
I'm having problems with the washer fluid mechanism in my 1990 protege.The switch seems to work and all my fuses are in good order. I've checked the hoses - no blockage. I've replaced the pump and still nothing!! Is it possible that I need to replace a connector or 2? There is really nothing in my Haynes manual that covers this and I have a hard time figuring out electrical diagrams. This minor problem is quickly becoming a major annoyance. Any suggestions would be greatly appreciated.
Old Aug 19, 2006 | 11:28 PM
bkey71's Avatar
Default RE: washer fluid pump/connectors?
Have you checked to make sure there is power at the washer motor when trying the washer? Check the BLU/ORG for 12V with a test light. The BLK wire is ground. Make sure the ground connection is tight too. The washer runs off the same fuse as the wipers, so if the wipers come on the fuse is okay.
Lions7
Apr 19, 2023 04:18 AM
rikardo76
Jan 23, 2009 02:01 PM
chunkdude
Sep 22, 2008 08:48 PM
cass328
Jan 30, 2007 03:48 PM
xspence
Feb 17, 2006 12:07 PM
