Washer fluid motor busted - 98 protege
Old Sep 22, 2008 | 04:16 PM
chunkdude's Avatar
Default Washer fluid motor busted - 98 protege
so my windshield fluid motor stopped working. when i try to use it, the wipers go just fine but no fluids come out, no spray sounds at all. so im guessing i need to replace it. my question is, is this something i can do myself, or do i need to get it done at the shop. ive got the haynes manual for my car but it doesnt cover this particular problem.
its a 1998 protege lx touring, 1.8L engine.
Thanks
Old Sep 22, 2008 | 07:37 PM
wsoape281's Avatar
Default RE: Washer fluid motor busted - 98 protege
the installation should be really simple if you are mechanically inclined. i imagine that, since you have a hayne's manual, you are. it should just be a positive line and a ground line for electronics and hoses. it may be a little hard to get to or find but the install shouldn't be hard.
Old Sep 22, 2008 | 07:39 PM
MazdaES's Avatar
Ok,
First thing is to soak the Haynes manual in gasoline and light. Use to heat the garage.
1. The washer motor is at the base of the washer fluid tank.
2. Remove the right front mud guard. (2 screws facing down into the the bumper cover and fender) Pull out to get full veiw of tank.
3. there are two screws and a clip to remove the washer tank.
4. unplug the motor, and remove the black hose.
5. The motor pulls off the bottom of the tank with a little force. try a flathead screw driver.
6. put new motor on and put it all back together. (check make sure motor works before putting all the screws in.
7. Wahsre motor is a $20 part.
Old Sep 22, 2008 | 08:39 PM
wsoape281's Avatar
ORIGINAL: MazdaES
Ok,
i like that. i would still rather have a haynes than a chilton's, but they are all vague and mostly useless. i could learn just as much standing at autozone for a little while.
Old Sep 22, 2008 | 08:48 PM
MazdaES's Avatar
Yeah, Chilton's don't even burn well.
rikardo76
Jan 23, 2009 02:01 PM
shipo
Jan 10, 2009 10:21 PM
cass328
Jan 30, 2007 03:48 PM
mazdadad
Aug 19, 2006 11:28 PM
xspence
Feb 17, 2006 12:07 PM
