Hello everyone, I need to replace this rusted pipe line which runs from the power steering fluid reservoir down to the front radiator. I have unscrewed all the brackets that hold it, and detached the steering fluid reservoir, but there is not enough room to wiggle it out, there is a small slot where it extends through to the front of the radiator that is limiting movement. I don't know what else to do in order to get this pipe out. Should I remove the radiator? Or another part? Thanks in advance!
Hi Wadesun. Were you able to figure a solution to get it out? I've just come across the same problem.
Thanks!
