Steering fluid - oil cooling pipe replacement
Hello everyone, I need to replace this rusted pipe line which runs from the power steering fluid reservoir down to the front radiator. I have unscrewed all the brackets that hold it, and detached the steering fluid reservoir, but there is not enough room to wiggle it out, there is a small slot where it extends through to the front of the radiator that is limiting movement. I don't know what else to do in order to get this pipe out. Should I remove the radiator? Or another part? Thanks in advance!
https://cimg5.ibsrv.net/gimg/www.maz...55d31853e6.jpg https://cimg9.ibsrv.net/gimg/www.maz...ba03c5c995.jpg https://cimg4.ibsrv.net/gimg/www.maz...8410f1b86d.jpg |
Power steering line problem
Hi Wadesun. Were you able to figure a solution to get it out? I've just come across the same problem.
Thanks!
Originally Posted by wadesun
(Post 173799)
