Shifter Loose
Old Mar 29, 2014 | 09:17 AM
Rockstar's Avatar
Default Shifter Loose
2002 Mazda Protege5
Shifter normally has resistance when travelling through the gears. Lately, from time to time, it is extremely easy (almost loose) going into gear but goes into gear fine and stays in gear. This lasts for a couple drives then it's back to what I'd call normal resistance moving between gears. Is this a linkage / bushing issue or something more I need to look at?
Many thanks!
Old Mar 29, 2014 | 06:22 PM
tanprotege's Avatar
I think you are on the right track. Check the bushings.
Old Mar 30, 2014 | 06:54 PM
Juanky's Avatar
if the shifter has a lot of travel from side to side, the bushings are gone. they are plastic and very cheap. you will be amazed by how nice is to operate the shifter when you replace the bushings. the 2003 protege has 6 bushings. i bought them at $1.25 each. the 4 at the ends are easy to replace. the 2 at the middle of the rod (there is like a joint there) requires you to grind the rivet out, install the bushing and replace the bushing with an appropriate bolt. the kind that has threads only at the end. i bought the bolt at home depot. lubricate the bushings with silicon grease, and use locktite blue thread lock on all the bolts.
Old Jun 21, 2014 | 09:29 PM
needs_more_mazdaspeed's Avatar
I have a similar problem in my 03 5spd dx. Where can I get those bushings?
Old Jun 22, 2014 | 02:53 PM
Juanky's Avatar
i bought them from a mazda dealer. if you plan to replace the pair where you replace the rivet by a bolt (and you should), try to get the shortest bolt that will fit, or cut the the bolt flush with the nut because it will contact a braket and you wont be able to shift. just cut it flush and try it. if it hits anything just remove the bolt install the bolt from the other side.
Old Jun 23, 2014 | 02:32 PM
gomazda3's Avatar
try aftermarket threaded shift *****
Go Mazda 3 - Mazda 3 parts and a huge selection of Mazda 3 parts at low prices!
Old Jul 13, 2020 | 08:35 AM
curiousnik's Avatar
Default size?
what size was the bolt? i’m at home depot now.
Old Jan 21, 2026 | 09:01 PM
FloppyShifter's Avatar
Photo of loose/worn shifter bushings
Bumping old thread to ask for recommendations on OEM vs. short shift kit. I just bought this '02 Protoge5 with very worn shifter bushings. Stays in gear, but shifter flops side to side easily.
Should I buy this short shift kit from Exile
https://exileautoworx.com/shop/short-shifter-bushing-combo/
Buy this one from Ralco
https://www.ralcorz.com/product/shifter-for-mazda-protege-99-03/?ref=Liza&gad_source=1&gad_campaignid=21743483723& gbraid=0AAAAAC0B1FfOnzDJIKdGqvYhM1ra94aqy&gclid=Cj wKCAiAj8LLBhAkEiwAJjbY7-OKd5lJUawUG
Or just skip the short shift idea and buy something closer to OEM? I'm honestly not sure if I'd like having a shorter shift throw. I do love heel-toe downshifting, but this is gonna be my daily driver and I don't want the shift to be finnicky/easy to slot into the wrong gear when I'm not paying attention.
Edit: please help me fix formatting of links.
Jsanti17
Sep 14, 2019 02:37 AM
Squatcho
Jul 23, 2011 07:25 PM
MazdaShock02
May 7, 2010 12:39 AM
ctsphoto
Feb 8, 2010 05:05 PM
STEVE SVENSON
May 19, 2009 11:46 AM
