noobe here with a question
Old Feb 16, 2011 | 08:38 PM
bigJ78's Avatar
Default noobe here with a question
im working on a '97 protege lx it has the 1.5. It will hardly idle and if you have all the accessories on like lights, heater etc on it will idle a little better. If you give it gas or even tap the throttle it will start idleing around 300rpm's and be very rough and usually dies any idea's. I replaced the EGR boost sensor with the 2 vacume lines on it. It seemed to help a little.
Old Feb 19, 2011 | 06:04 PM
darkstar4100's Avatar
sounds like a vaccum leak i had something simular to what your having on my gf's car i took the throttle body off the manifold and the gasket was in about 10 pieces so i made a gasket out of that gasket material you can buy at an auto parts store and the idle went from 300ish rpm to about 800
Old Feb 23, 2011 | 04:48 PM
bigJ78's Avatar
Well I checked all that I can for vaccum leaks and I still havent come across any. When it does run it has absolutely no power does this help???
Old Feb 23, 2011 | 05:25 PM
bigJ78's Avatar
I hope this helps too. It is fine till it warms up then the idle goes to ish. It has power till it warms up too. Any ideas????
Old Feb 23, 2011 | 09:37 PM
DCU1976's Avatar
Default ?
Maybe a timing issue?
HARHARHARHAR
May 5, 2009 04:02 PM
Soulchaser
Mar 14, 2009 10:51 PM
vette92
Jul 2, 2006 03:12 AM
mazda guy
Oct 21, 2005 04:44 PM
imlikeojnow
Aug 1, 2005 03:49 AM
