Need help in replacing belts on 03 protege... please
Old Jun 27, 2009 | 09:04 AM
huntindad's Avatar
Default Need help in replacing belts on 03 protege... please
I've searched and can not find any other post on how to.
my alt. belt broke, so I figured I'd replace both belts. I have the belts, but after looking at the belt/pulley system, I do not see an easy way to replace these puppies. I was hoping to find a tensioner to undo and swap out the belts and... wa la. No such luck.
Any Ideas ? What is the trick to this go cart?
thanx,
David
Old Jun 27, 2009 | 02:09 PM
eeuler's Avatar
loosen the alternator and power steering pump, this should release the tension from the belts so you can pull them off. Check the tension of both belts so you know how much tension you need to put back onto the new belts.
Old Jun 27, 2009 | 10:16 PM
huntindad's Avatar
thanx for the info. another question though...
for the alternator, is it easier to loosen from the underside?
Kinda looks like it from what I have seen from the top.
Old Jun 28, 2009 | 05:15 PM
eeuler's Avatar
yeah, there isnt even enough room to get the alt out from the top if you wanted to take it out.
windbk
Apr 9, 2013 04:07 PM
Skrappi69
Oct 8, 2009 11:13 AM
sparkelle1
Feb 4, 2008 12:55 PM
MazdaSilva
Jun 21, 2007 10:46 PM
ckc55
Mar 30, 2007 09:18 PM
