Squeeling Belts on 2000 Protege
Old Jan 25, 2013 | 11:28 PM
windbk's Avatar
Default Squeeling Belts on 2000 Protege
Hey all,
Just a question about the belts under the hood of the protege (1.8L).
I know it's pretty common for these to squeek a little when it's cold. But, Mine seem to be making a pretty high pitched squeel sound, until the engine is at normal operating tempature.
Any ideas/thoughts what it could be causing this? ideas to fix it?
Thanks!,
Old Jan 26, 2013 | 10:40 AM
tanprotege's Avatar
There is a pretty long thread on this topic somewhere here.
Important points are:
Proper belt tension.
Use top quality belts.
Check for a polished look on the alternator pulley. If it has a smooth glossy look use sand paper on the flanks of the grooves to proide a bit of friction for the belt.
And here is a 'Don't": don't use belt dressing.
Good luck!
Old Apr 9, 2013 | 10:51 AM
windbk's Avatar
Sorry all for the delayed reply.
Turns out it was a bad mounting bracket that was causing the alternator to move/wobble, hence the squealing. That's been fixed, but the battery light is staying on in the car. Could the entire alternator unit be bad?
Can anyone suggest places that might do a free load test of the unit?
Thanks!,
Dan
Old Apr 9, 2013 | 01:08 PM
Kevinkpk's Avatar
It could be. I don't know where you are located, but Autozone will test it. I have a voltmeter so any electrical issues I can (usually) resolve.
Old Apr 9, 2013 | 03:04 PM
Thanks!,
Dan
YES it could be damaged due to not running true, putting strain on bearings, etc
Old Apr 9, 2013 | 04:07 PM
tanprotege's Avatar
Vorsath
Apr 21, 2013 08:15 AM
GuyLaProtege
Jan 24, 2012 01:23 PM
huntindad
Jun 28, 2009 05:15 PM
achrukme
Sep 8, 2008 07:39 AM
grenier83
Aug 2, 2008 07:48 PM
