Mazda Protege BJ1 2000 Power Window Relay
So after removing the stank Mongoose alarm wiring and returning the car back to factory wiring and fixing all the door locks and all the power windows im stumped on Drivers Side power window. Alarm installers (from 20 years ago) depinned the door connector as well but thats also been returned back to factory. Now I got one power window left to fix. ive got other proteges (BJ2) to cross reference wiring on the switch so I know which two wires are the power wires for the drivers side window on the main switch. Im getting no power from the switch for the drivers side but all other windows work. Fuse is good so I thought Id get under the dash and test the relay but there isnt one there. There is a relay for the fogs, door locks and flasher but nothing for the windows.
So question is: Does anyone know where the power window relay is located for BJ1 Proteges or have a picture of what it should look like under the dash where the relays are cause Im seeing nothing under there related to the windows. Im hoping the alarm installers 20 years ago didnt cut the wires and hard wire the other windows in cause Im pretty close to hard wiring power or creating a custom relay for the damn drivers side window. Id like to avoid it so if I ever get rid of the car, the next owner will be able to do any maintenance if required. Thanks in advance.
Ive also pulled another door harness from the wrecker and same thing
Make sure the door wire harness is reconnected properly and that there are no damaged or cut wires. Sometimes wires can be hidden or reconnected incorrectly.
