2002 MILLENIA S POWER WINDOWS NOT WORKING
Hello all, if anyone can help. I had my engine recently shampooed but the the washer left it running during the wash. Afterwards the power windows stopped working. The power mirrors function (the same switch panel) but not the windows on the drivers control panel or the individual switches on the other three doors. I can hear a very mild buzz from the drivers main switch for the driver door whne pressing up/down. I checked the main 60amp fuse and the 15 amp fuse seem OK. The engine was detailed a before the winter but off and no problems occured. Any help would be appreciated.
Thank you! alexdb7@hotmail.com
RE: 2002 MILLENIA S POWER WINDOWS NOT WORKING
They probably got water inside your power window relay. Might want to remove the relay anddry both relay and connector tosee if that helps. Relay is located just in front of the main relay/fuse box in the engine compartment. There should be two of them mounted there. The power window relay has four wires to it. Two of them are Blue with a Black stripe. One is Green with a Red stripe and last wire is Black with a Red stripe.
