Idling Issues after replacement parts.
Old Oct 2, 2012 | 09:21 AM
pixelmonkie's Avatar
Default Idling Issues after replacement parts.
I have 2002 Pro5 and my check engine light came on. I got the codes pulled on it and it was P0037.
So I decide to do some maintenance on it:
  1. Check intake hose for cracks and was secured
  2. MAF removal and cleaned
  3. Replaced spark plugs
  4. Replaced O2 sensor rear
Check engine light gone running a bit smoother; however when I brake to a stop or at a stop my car is idling hard as if it wants to cut off.
Any ideas on what I can do or the problem?
Thanks,
Pixelmonkie
Old Oct 2, 2012 | 11:25 AM
tanprotege's Avatar
Pixelmonkie:
This deep drop of the idle often is caused by a malfunctioning EGR valve. I suppose it doesn't completely close.
So, take it out clean it well and make sure the valve moves with ease. Also make sure the nipple for the vacuum hose that goes to the EGR boost sensor is not clogged. It sits on the back of the intake manifold in my 98 protege.
Old Oct 2, 2012 | 12:01 PM
thanks a bunch I will have to try... I'll post the results afterwards.
kuksoolwon88
Jul 19, 2006 10:12 PM
DoctorX
Nov 23, 2005 03:37 AM
supabenben
Aug 31, 2005 08:29 PM
beartoes
Jun 12, 2005 03:34 AM
marcy
Jan 3, 2005 10:00 AM
