Crazy Speedometer and Instrument Cluster Lights
I have a 2003 Protege, automatic w/o ABS. Two issues: 1) The speedometer registers zero most of the time. Some times it freaks out and shows wild speeds. My wife swears it did a complete 360 going past 140 MPH then settleing back to zero.
2) The insturment cluster illumination lights not working. Tested bulbs for continuity and got OK readings. But, there are only two bulbs back there. The third (smaller) one is missing. So I switched one warning bulb into the open socket but still noting. All warning lights operate. I also tested the incoming wiring harness for voltage and read around 12 volts.
Thank you for any help.
That is a problem will ALOT of brand of cars. You can send it to get repaired, might be cheap enough to warrant that.
mazda_guy666
Jan 21, 2010 07:02 AM
SlowG60
Dec 12, 2009 12:14 AM
