A/C question
Old Jun 1, 2011 | 02:48 PM
tanprotege's Avatar
Default A/C question
Hi guys. I have a '98 Protege LX, 1.5L. The A/C clutch bearing is shot. Is it possible to replace the A/C clutch including the bearing without taking the A/C compressor out of the car? It sits mighty close to the sidewall.
My A/C worked but made a lot of bad bearing noise. I currently use a by-pass belt.
Thanks in advance.
Old Jun 4, 2011 | 01:43 PM
tanprotege's Avatar
This message gets a lot of looks but no answer yet. If you can't answer my question directly I definitely will appreciate if you could tell my how you dealt with replacing the AC clutch bearing, short of installing a new AC compressor.
Thanks!
Old Jun 13, 2011 | 02:13 PM
tanprotege's Avatar
Hi guys: Since no one cared to answer I have to answer the question myself: yes, you can. Remove the wheel, remove the under body splash guard and access the compressor from below. There is enough room to work on the compressor clutch assembly.
Old Jun 17, 2011 | 01:25 AM
captaintony's Avatar
Default help
I am having the same issue in my 96 protege 1.5L the ac works great except the compressor clutch assembly is going out(grinding noise)... i have done a of research online and cant seem to find the clutch assembly, it seems like i have to buy a new compressor and clutch assembly that sucks!!! 1.5 yrs ago i had all the ac stuff replaced and i want to get out of this fix for cheap any insight would help.
Old Jun 28, 2011 | 06:20 AM
webf2011's Avatar
I didn't face such issues yet. Even am still awaiting for the best solution to this problem, so that in future i can deal them easily.
Old Jun 29, 2011 | 08:43 AM
tanprotege's Avatar
I ordered my compressor clutch bearing from "Coldzone777" and I watched YouTube videos on how to replace the clutch bearing. I had no problems getting it done in about 2 hours, and I am a slow poke.
stpetejack
Aug 31, 2007 04:40 PM
lacawi
Aug 1, 2007 07:12 AM
