Broke timing belt
Old Dec 2, 2021 | 09:54 PM
Brenda Moore's Avatar
Default Broke timing belt
99 mazda 1.6 protege I replaced timing belt. The whole kit. Reset timing. Tried to crank it but no luck. Spins but no start. I need correct way to set timing after replacing broken belt. I've got no fire at the crank sensor. I'm not getting anything from the ECM to sensor. I need correct way to troubleshoot my crank sensor.. I'm not sure if I've done the timing and sensor check the correct way. I'd appreciate
Old Dec 8, 2021 | 06:08 PM
Blader's Avatar
Look on utube theres a few videos of how to set timing there, most likely you dont have the timing right, the balancer on bottom has a notch to line it up to. The cams also have to be in correct position if belt off by 1 tooth it wont start..Good Luck
beaverboy909
Sep 5, 2011 08:46 AM
billbon8
Sep 5, 2011 08:39 AM
TEDA
Oct 6, 2008 04:44 PM
Roleary
Apr 25, 2006 10:20 PM
