98 Protege manual transfer starting issue
Old May 18, 2013 | 09:35 AM
Allegraman23's Avatar
Default 98 Protege manual transfer starting issue
Hello,
Just recently I had a starting issue with my Mazda protégé. It is a manual five speed transmission and to start I have to push in the clutch and then turn the ignition.
What is happening is when I push the clutch in and go to turn the ignition nothing happens no cranking.
To sometimes get a start I will put it in gear and push the car a couple feet and then I can start the car.
Wondering if I have a starter issue or a clutch switch issue?
Thanks for any suggestions.
Allegraman
Old May 18, 2013 | 12:45 PM
Kevinkpk's Avatar
One way to find out, check for voltage at the switch, if you have it, jumper the two wires together. Do this with the car in nuetral, then try to crank it.
Old May 19, 2013 | 07:18 AM
Kevinkpk,
Am I looking for 12v?
Allegraman23
Old May 19, 2013 | 11:36 AM
tanprotege's Avatar
yes......
Old May 19, 2013 | 03:00 PM
Kevinkpk's Avatar
This should be a normally open switch with 12 volts on one side, the other to the (I think) BCM that allows it to start with the clutch in, the switch will close allowing it as a permissive. Again, don't try this without the transmission in nuetral.
eptrois
Feb 11, 2014 09:46 AM
shaun ayres
May 21, 2010 11:32 AM
323owner
Sep 28, 2007 10:46 AM
caballero213
Sep 17, 2007 11:37 PM
metzeller
Feb 16, 2007 11:15 PM
