surging under acceleration
Old May 20, 2013 | 10:21 PM
whatusername's Avatar
Default surging under acceleration
ok so i have this annoying problem with my p5 it surges under moderate to hard acceleration also sometimes notice it on decel.I have been trying to fix this problem since i bought the car back in feb. i have no cel light no codes now does not backfire under decel. No misfire. What has been done so far is intake manifold gasket replaced, mass air flow cleaned, egr cleaned, iac cleaned, exhaust manifold gasket replaced, 1.8 coil conversion so coils replaced, throttle body cleaned, injectors replaced, fuel pressure regulator solenoid replaced ,plugs replaced ,wires replaced, intake hose thoroughly inspected for leaks and cracks and is in great shape. vaccum lines checked. i am out of ideas. can anyone help?
Old May 21, 2013 | 08:19 AM
tanprotege's Avatar
Have you tested the throttle body position sensor?
Have you tested the fuel pressure?
Old May 21, 2013 | 01:01 PM
no have not tested tps as i dont know how and i was gonna test the fuel pressure but there is no fitting to hook uo the gauge im guessing it goes inline somewhere and i looked at the fsm and saw there little illistration but it was not clear as to where they hooked it up
Old May 21, 2013 | 01:17 PM
tanprotege's Avatar
There are several videos on Youtube on TPS testing. I.E.:
and this should help with the fuel pressure:
Good luck to you!
Old May 23, 2013 | 01:33 PM
thats was actually kinda usefull i dunno y i didnt think of youtube thanks... im leaning towards fuel pump still didnt test it yet but will soon
abhaslaj
Oct 6, 2020 11:12 PM
MilleniaMan
Nov 28, 2013 11:02 AM
bgdesign
Aug 12, 2011 11:14 AM
alexgohard
Oct 18, 2006 10:30 PM
2fivestangbtr
Feb 14, 2006 03:57 PM
