98 protege lx wont start....
Old Jan 26, 2008 | 04:16 PM
TheClaw555666's Avatar
Default 98 protege lx wont start....
hey guys, i'm new here. i'm usually one the bimmer forums, but my girlfriend drives a 98 protege lx, so it has the small engine in it, 1.5 or 1.6 i cant remember. but either way it has a problem starting, like it wont at all. when you turn the key it just clicks. the starter is not even engaging. the click it makes sounds as if its coming from the dash, underneath the glove box. its got about 170k miles on it. and it has been extremely cold lately, so i initially thought, there may be and ECU problem. but if you roll start it (cause it is a 5 speed) then it runs fine. so then i knew its a starter problem, but since the starter is not engaging, my thoughts went to starter solenoid. i've never messed around with one of these cars, i'm a european only mechanic. do these cars have a starter solenoid? and is it a common problem or anything? or should i just change out the starter?
Old Jan 26, 2008 | 04:18 PM
Default RE: 97 protege lx wont start....
oh, and i have checked the battery and everything, all that seems to be working fine. it will not even start with a jump pack or jumper cables attached to it.
Old Jan 27, 2008 | 12:32 AM
wsoape281's Avatar
did you check the ground wires?
Old Jan 30, 2008 | 08:40 AM
yea, i've checked all the battery wires and what not. all the connections seem fine. i'm thinking starter or starter solinoid, because every once and a while when your trying to start it, you'll hear the starter click out, but not engage. its not grinding or anything, so i thats why i was thinking solinoid. there was some corrossion on the both battery terminals, but that was the first thing i did was clean all that off and still not change in the car
brentu777
May 30, 2011 01:39 PM
QG9721
Nov 23, 2010 04:26 AM
irongiant369
Mar 18, 2007 12:21 PM
dr4g0n3
Mar 13, 2007 12:08 AM
DragOnKustums
Nov 9, 2006 05:22 PM
