98 protege 1.5 missing when wet @low rpm
I have a 98 protege that started to miss at low rpm when it was damp outside. The problem has been getting progressively worse and happens all the time. I've replaced the spark plugs & wires, distributor cap, rotor and most recently the distributor. Nearest Mazda garage is quite far. I've spent quite a bit at two garages to no end. Any suggestions would be appreciated.
Thanks.
Thanks.
OK as per my previous post these are the current codes coming up
1 P0100-mass or volume air flow a ciruit
2 P0110-intake air temp sensor 1 circuit
3 P0170-fuel trimbank 1
4 P0302-cyl 2 misfire detected
