Timing wont stay set
Old 12-01-2010, 05:51 PM
Doug_ATX's Avatar
Default Timing wont stay set
B2200, just rebuilt.
What would cause the timing to keep changing each timeI check it?
Set it at 6*. Drove it 3 blocks..it was at 10*. Set it at 6* again...drove 3 blocks and it was at 4*. Im so confused... Could it be a loose timing belt?
Thanks
Old 12-02-2010, 09:56 AM
Cusser's Avatar
Is the vacuum advance connected or disconnected when you set or check the timing? If connected, engine rpm can affect the vacuum.
Old 12-03-2010, 08:39 AM
Doug_ATX's Avatar
Thanks for the reply. It was simply an inconsistent idle speed. Thought my ear was good enough to judge RPM but apparently not!
Old 12-03-2010, 07:52 PM
So Doug, what was causing the inconsistent idle speed? 'Had to be some other problem or it would be more steady.
Old 12-03-2010, 10:23 PM
Doug_ATX's Avatar
Weber carb. Electric choke. I think I need to jet-up too. Anyway, its running great now. Just needed to full warm up and set/check it. Too used to FI I guess (and tachometers )
Old 12-04-2010, 07:31 AM
Yup, it helps to have the engine fully warmed up before trying to set the timing.
Why do you feel the need for bigger jets?
Where in Austin are you?
Old 12-04-2010, 02:37 PM
Doug_ATX's Avatar
SW Austin, Oak Hill area.
Unless I have a vacuum leak I cant find, I'm having to richen the mixture more than the 2.5 turns that Weber claims would be sufficient. I'm at 3.5 turns. Although it runs great, if my first milelage test comes out poor I think it may need different jets.
The block is bored over, and it has one of those pacesetter headers on it (POS I know, but more flowing than the 200lbs of crap that was bolted on there previously).
We shall see!
mike4ua2001
10-16-2011 11:03 AM
steven lemire
03-21-2009 05:22 PM
frncscchavez
07-18-2007 08:34 AM
Nskylinerb25
10-21-2006 12:18 AM
futurevip
10-15-2006 04:06 AM
Quick Reply: Timing wont stay set
