rogh idle, stall problem
Old 11-05-2010, 11:33 PM
jarrod's Avatar
Default rogh idle, stall problem
hey all.. new here.. im workin on my buddys 91 b2200(fi) now got it to start, but idles rough. and if you give it any gas it stalls.. but will idle..and if you let off the gas it was go back to idling after it tries to stall..
has a newish fuel pmp.(was done under a year ago, but truck was stored for alot of that.) has good spark, and a good injector pulse..
ive played with the timing but to no avail..
i also just did the head gaskt, and ive checked the cam/distributor timing about 12 times, and it seem to be good..
any other ideas as to what it could be??
thanks
Old 11-06-2010, 09:00 PM
hayfieldfarm's Avatar
Fuel filter?
Old 11-07-2010, 12:14 AM
Cusser's Avatar
make sure the EGR valve is closing at idle.
Old 11-17-2010, 07:34 PM
jarrod's Avatar
well i still cant this thing to work... and where the heck is the egr on the efi models?
compression test was good(170-175 across the board) new plugs, cam/dist. timing is good.. good injector signal.. but still pops thru the exhaust and doesnt run worth ****.. and NOT throwin a code..
Old 11-20-2010, 09:40 PM
Cusser's Avatar
Good question - I'm not sure EFI models have them.
jordoe28
04-04-2015 08:45 PM
NursemyMazda
11-20-2012 03:37 PM
vijaykiran
10-12-2009 06:27 AM
jmk1
01-30-2009 06:08 PM
omkhaf
03-03-2007 07:26 PM
Quick Reply: rogh idle, stall problem
