MX-6 stalls and won't start intermittently
I have a '93 MX-6 with the V-6 engine. I cleaned the negative contact on the battery of acid one day and ever since I've started having these problems. I replaced the negative battery contact. When I'm driving (either city or highway) the car will just die. And sometimes it won't start at all. I am fairly certain that it is not a fuel delivery problem. So I brought it to a mechanic to see what was wrong with it and he told me it was the distributor. So I replaced the distributor and it started up right away and while I was adjusting the timing, the car died and it won't start up since. The battery is dying because I've been cranking the engine so much without it actually firing. I made sure I put the spark plug wires in the correct order in the distributor. Has anyone else had this problem or have any idea what might be wrong?
Thanks,
Lance
Thanks,
Lance
RE: MX-6 stalls and won't start intermittently
We may have a similar problem. Talked to my mechanic and mention testing fuel pump if working. He said the way
to check it was removing the upper hose of the fuel filter and have someone turn the ignition to ON position only
(don't crank all the way) while you check if gas spits out from the fuel filter. But I told him I got code 28 from my diagnosis and he said that was egr solenoid. He still strongly suspect it is the fuel pump. I'll try these testing today.
Are the battery connections ok? I ask because you stated you cleaned the negative contact. I had a problem with my mx6 not starting or just dying out on my for a while I found out that my battery connection was loose.
Good luck
Naveen
Good luck
Naveen
Orange_Monster
06-01-2011 05:44 PM
kavee
03-24-2011 01:13 AM
