2004 mpv lx miss when warmed up
Old Mar 30, 2019 | 11:49 PM
Chadwickflash's Avatar
Default 2004 mpv lx miss when warmed up
I am new to the forum mainly joined cause I own two Mazdas that require work. My girlfriends mpv likes to miss once it is warmed up. It will drive without losing power but will idle low. It does have the 3.0 6cyl. I was going to go ahead and redo the spark plugs and see how that does. Any other suggestions I would love to take them
Old Apr 22, 2019 | 05:40 PM
bruh's Avatar
It's most likely the coils. It's a known issue and probably one of the most common repairs for the MPV. It's the ONLY real engine issue I've had on my MPV. You'll feel an occasional hiccup as you accelerate or cruise, and it will get progressively worse over time. Eventually it will throw an engine code to the OBD2 computer and light your check engine dash light. I waited for that to happen, then used a cheap bluetooth code reader and the "torque" app on my smart phone to diagnose the check engine code. I found out it was misfiring at the #4 cylinder (unfortunately on the back side of the engine). The coils sit on top of the spark plugs and they are expensive from the dealer. I bought a replacement set of 3 for about $38 on Ebay.
Replacing the coils is very easy, BUT getting to the rear coils is very difficult. You have to remove the intake manifold to access the rear spark plugs/coils (a major hassle). There are several guides online if you google "MPV coil replacement". The MPVclub forum, Mazdaforum, and 247Mazda forum all have threads about it. I only bought a pack of 3 coils because I knew only one of the coils was acting up, but since it's so hard to access the rear spark plugs, I replaced all 3 of them. I saved the 2 other still working coils and ended up using them to replace coils on the front side of the engine when they eventually failed. The front side is very easy to access and the replacement on that side is literally a 5 minute job.
Old Aug 27, 2019 | 07:47 AM
Jennitran's Avatar
Originally Posted by Chadwickflash
I am new to the forum mainly joined cause I own two Mazdas that require work. My girlfriends mpv likes to miss once it is warmed up. It will drive without losing power but will idle low. It does have the 3.0 6cyl. I was going to go ahead and redo the spark plugs and see how that does. Any other suggestions I would love to take them. Visit this link to know how long can i drive with a misfiring cylinder that you may concern.
You should check if there is vacuum leak or not. When checking for the vacuum leak be sure to spray the large black hose from the MAF to the throttle body too.
okayfine87
Oct 13, 2012 07:22 PM
andrewt71
Mar 21, 2009 01:06 PM
rmsowell
Sep 5, 2008 01:04 PM
hfont
Jul 7, 2007 11:57 PM
justtracie
May 31, 2007 07:30 PM
