2001 MPV Shifter cable broken..... need part name/number
Old 02-01-2018, 05:53 PM
317Highlander's Avatar
Default 2001 MPV Shifter cable broken..... need part name/number
I have a 2001 Mazda MPV. When I got home from the store the other day and shifted into park, the shifter traveled past the normal position (almost vertical) and now the dash reads Neutral. I can pop the shifter loose and it flops up and down, but the car stays in Neutral. I have searched and searched and found two possible problems. 1, the Neutral Safety Switch and 2., the shifter cable. The problem is that I can't find anywhere that gives a result when I search for "MPV Shifter Cable" or "Trans Cable" or "Shifter linkage".
Someone please help. I have a place that will do the labor for free, but I have to supply the part(s). I wanted to take both to him, but can't find the cable or even what to call it.
Old 02-02-2018, 03:04 AM
Ring your local Mazda dealer, give then your chassis number & ask for a shifter cable.
Fammies
10-22-2017 10:11 AM
blthomas
03-29-2012 11:39 AM
Marjnal
06-01-2011 06:36 PM
safa
04-07-2008 05:28 AM
scoobyrunner01
03-04-2007 01:58 AM
Quick Reply: 2001 MPV Shifter cable broken..... need part name/number
