PO 170 & PO 173 codes
Old Oct 21, 2007 | 08:03 PM
JJohnsonAZ's Avatar
Default PO 170 & PO 173 codes
Hi All,
these are the codes for our 2002 Millie S. The Auto Zone folks said it is the mass air flow sensor. I see where it is in the compartment, but just acouple things...is this something I can replace on my own, and is there a good source or can I just have Auto Zone order it for me...~$195.00.
Thanks in advance for the help.
Jay
________
Honda NSS250
Old Oct 21, 2007 | 08:49 PM
Tbird's Avatar
Default RE: PO 170 & PO 173 codes
Hey welcome to the forum, did you make sure it is bad? cause i had that code on my milly but its cause i had a vaccum leak after the mass sensor which triped the computer and i found the leak sealed it and instantly the code when away. just an option you can look at..see ya
Old Oct 21, 2007 | 08:52 PM
keninn's Avatar
way to go. throw parts at it till the codes go away. i am continually amazed at what people believe. is it because autozone has a scanner, and can read from a book?
these are fuel trim codes. classic case of vacuum leaks, 50 bucks says it is one or both vacuum tees. the tees are a couple of bucks apiece, but the labor to change them is a few hours. easily done, or impossible, depending on your mechanical expertise. takes me about 2 hours, including breaks. you will have to remove the intake. or you can do like autozone says, replace the mas. but that aint it.
Old Oct 22, 2007 | 01:48 PM
JJohnsonAZ's Avatar
thanks Tbird...I joined about a year ago, and rec'd a ton of help from babyhuey and just have not had any issues since then, but this is just a great forum to get ideas and such. I'll try to verify the cause. Appreciate the heads up.
________
Triumph Speed Twin
simmonsp5
Sep 21, 2023 04:49 PM
brad follack
Aug 5, 2011 10:06 PM
kickerzx2
Jul 8, 2005 11:00 PM
dans mazda
Apr 7, 2005 06:15 PM
ollie
Feb 23, 2005 01:25 PM
