fuel filter change
Old May 30, 2007 | 12:36 PM
kirk98s's Avatar
Default fuel filter change
hello everyone,
i need to change my fuel filter. i saw a while ago and saw someone posted the diagram of the truck and its location. could someone post this for me. i would be much appreciated.
kirk98s
Old May 30, 2007 | 02:28 PM
keninn's Avatar
Default RE: fuel filter change
you dont need a diagram. remove the carpet in the trunk, and up by the ski hole door, there will be a circular plate, gold, and i think 3 screws hold it down. you cant miss it. under that plate is the filter. this is not a fun job. i get at it thru the ski door. i sit on the back seat, and go at it from there. it is really tight, and if you got big hands, it is worse. everyone has theories on how to get it so there wont be any fuel pressure in the system. none of them work. you will spill some fuel. i would let it sit overnite, then loosen the filler cap, then pull the filter. i think then you get the least amount of fuel spilled. doing the run the car then pull the fuel pump relay is worse. make sure you look at the filters, otherwise, you might install it backwards.
Old May 31, 2007 | 09:30 AM
kirk98s's Avatar
thank you sir,
do i need any special tools to remove hoses and stuff?
kirk98s
Old May 31, 2007 | 10:01 AM
keninn's Avatar
no, but it is really tight in there. getting the spring hose clamps off is not easy. there is a cable hose clamp tool, but i dont have one. there is a bracket that holds the filter to the tank, and iirc, there is a carriage bolt. if that sucker is rusted, you will have a heck of a time getting the filter off. lots of rags to catch the fuel spill, and lots of ventilation.
Old Jun 8, 2007 | 04:08 PM
lmeadows52's Avatar
Keninn, Thanks for reply yesterdayre: oil type. Where is the fuel filter located on the 96 S?
Old Jun 8, 2007 | 04:16 PM
babyhuey's Avatar
Fuel filter is located in the same place on all Millenia.
[IMG]local://upfiles/1377/C55C4EA5240D4587B57E596675F955EC.gif[/IMG]
DjSlickSVG
Jan 27, 2014 11:29 PM
AntonA
Aug 24, 2009 03:49 PM
lmeadows52
Apr 22, 2008 02:38 PM
andy936867
Oct 20, 2007 04:10 AM
Airborne Ranger
Jul 4, 2005 05:05 AM
