96 milly s fuel filter change
Old Apr 18, 2008 | 07:12 AM
lmeadows52's Avatar
Default 96 milly s fuel filter change
I'm going to try to access/change my fuel filter on 96 Milly S. Is the filter under pressure? Do I have to disconnect the battery or do anything else before changing the filter?
Old Apr 18, 2008 | 07:24 AM
keninn's Avatar
Default RE: 96 milly s fuel filter change
yes, the filter is under pressure. you dont need to disconnect the battery. the book says to run the car, then pull the fuel pump relay and let it die. from past experiences, there is no way to avoid fuel splashing/leaking when the lines are disconnected. i just use some rags to catch the excess fuel, and have lots of ventilation. the fuel tank is recessed where the filter goes, so liquid will collect there, plus all kinds of garbage. i pull the vertical trim panel back there, and go in from the ski door, sitting on the back seat. depending on the condition of your car, there is one bolt that may be rusted. if so, the filter will be a real pain to get off. at best, you will have to contort a lot, and getting the spring clamps off the filter can be a chore.
Old Apr 18, 2008 | 07:33 AM
lmeadows52's Avatar
Thanks for the fast reply and help. Where is the fuel pump relay located? Also, I have the rear seat bench but there is no opening to the trunk area (there is a wooden panel in place). Do you think I could access the filter OK from the trunk?
Old Apr 18, 2008 | 08:13 PM
keninn's Avatar
pull down the armrest. there is a door there into the trunk, this is the ski door. you CAN get to it from the trunk, but you will be very unconfortable. the fuel pump relay is in the engine bay, right next to the cruise control actuator, driver side.
Old Apr 19, 2008 | 02:39 AM
dany8_1999's Avatar
Default 98 milly s fuel pump change
Hi guys, I'm trying to change the fuel pump on my 98 milly s, Does somebody know how to do it? Any help will be appreciated.
Old Apr 19, 2008 | 07:28 AM
keninn's Avatar
Default RE: 98 milly s fuel pump change
you wont like the answer. which is, you gotta drop the tank. have you priced a new fuel pump lately? and, if you are just going to get aftermarket, where you solder in just the pump, be aware that if it dont work, you will have to drop the tank again. also, some aftermarket pumps will kill the fuel pressure regulator, in which case you get to drop the tank again, PLUS buy the real pump.
Old Apr 19, 2008 | 08:01 AM
lmeadows52's Avatar
Thanks kennin for the good info.
Old Apr 21, 2008 | 01:52 PM
dany8_1999's Avatar
Thanks Kennin, I appreciate your advice.
Old Apr 21, 2008 | 01:57 PM
dany8_1999's Avatar
Another question, Do I have to drop the tank to check whether the fuel pump is good or not? thank you in advance.
Old Apr 21, 2008 | 08:16 PM
keninn's Avatar
ORIGINAL: dany8_1999
no. but you have to drop the tank to change it.
