water on passenger floorboard
Old Aug 24, 2006 | 06:23 PM
lgesaguaro's Avatar
Default water on passenger floorboard
Hi Everyone..
I have a 94 miata.... Recently, I have been hearing a wierd noise under the glove box when i turn right or left, and water comes out under the dash. I took the drainage tube off and it was plugged, but it still makes some sort of fan... whirring noise... kinda like some sort of fan is getting water in it when water is coming out.... even with the hose unplugged, and me wanting the water to go on the floor, it still comes from some area around the plug hole too....
does anyone have any idea what this might be? Do I have to take the whole dashboard out to figure this out?
help
Brian
Old Aug 24, 2006 | 10:47 PM
babyhuey's Avatar
Default RE: water on passenger floorboard
Water still in the heater fan area? Assume the drain hose you removed was further toward center of car for the evaporator. Have you tried removing the heater fan yet?
Old Mar 14, 2007 | 11:28 PM
Judgester's Avatar
In the event you have not gotten an answer. I have a 90 miata and it does the same thing. the issue is the drain pan. you have to take apart the whole dash to get to it and it most likely has mildew in it. This mildew creates a clog in the drain line. So even after you clean out the line it will not take long to clogg back up and the the waer will run again.
Sorry
timmonsr@gmail.com
Nov 9, 2013 03:25 PM
slaphappy
Aug 3, 2013 01:12 AM
msgntsu
Jul 3, 2011 09:03 AM
johnmsharkey
Jul 12, 2007 09:35 PM
austintitus3
Dec 29, 2006 02:59 PM
