M2 mysteriously loses power
Old 07-21-2018, 12:18 PM
adv's Avatar
adv
adv is offline
Default M2 mysteriously loses power
My 2001 M2 ran perfectly until a couple of years ago. Now, after starting up and running well for about 10 minutes, the engine suddenly loses most of its power. The exhaust note drops down very low, but doesn't sound irregular. It runs like this, with barely enough power to keep moving on a level road, for about 30 seconds, and then just as mysteriously it jumps back to normal and from then on runs normally. Sometimes it takes much longer to recover, and occasionally I have to turn off the engine and restart it. All the computer code reads is "misfire." One mechanic said it was the oxygen sensor, and replaced it to the tune of $300, but that didn't solve the problem. Another said it's the catalytic converter, whose replacement is even more expensive. Has anyone had experience with this kind of problem? More important, has anyone had it--and solved it?!
Old 08-27-2018, 08:11 AM
Dougal McGuire's Avatar
The lack of replies you’ve received might be because you’ve posted your question in the Miata forum. You might get answers if you ask the correct forum. Good luck!
poppashocker
08-25-2015 08:19 PM
Hurley
05-26-2009 10:38 PM
b1004
10-30-2007 08:43 AM
legacylight
09-28-2007 01:50 PM
Quick Reply: M2 mysteriously loses power
