need help with breaks
Old Jul 18, 2005 | 11:28 PM
maxboost9's Avatar
Default need help with breaks
The rear breaks the callepers wont compress to put pads back in what do i do please help
Old Jul 19, 2005 | 10:05 PM
gtxtreme's Avatar
Default RE: need help with breaks
You have to check the caliper piston if it has two v shape reliefs then you need to try using plier tha will fit in the v's and turn counter-
clock wise. If no v's on piston then look on the back of the caliper between the brake hose and hand brake cable bracket. There is
a hexhead plug, 12 or 14 mm, remove this, now you need a 5 or 6 mm allen wrench. Once again turn adjustment gear counterclockwise to pull the caliper piston back. Every time the hand brake is used, it will turn the adjuster if there enough free travel.
little dutch
Oct 14, 2013 03:13 PM
BCNorth
Jan 9, 2013 11:40 AM
supermanwithheat
Apr 24, 2007 01:27 AM
chefmaster25
Jan 26, 2007 10:59 AM
Alucard
Aug 29, 2006 12:55 PM
