Change Fuel Filter on 2008 CX-9
Old Jul 13, 2017 | 01:18 PM
paulflory's Avatar
Default Change Fuel Filter on 2008 CX-9
Had issue on inclines with jerking, thought is was transmission but when serviced indicated engine was missing. Replacing spark plugs took away most of problem but still have some sputtering on inclines. Wanted to run some fuel injection cleaner through and replace the fuel filter. I've seen some vague indication that this may be able to be accessed through a panel under carpet beneath the 2nd row seat. Has anyone done this and have advice on changing the fuel filter?
Old Jul 13, 2017 | 01:41 PM
shipo's Avatar
Are you sure your CX-9 even has a fuel filter? I ask because something like 80% of all cars built since the mid-2000s do not have such a filter.
Regarding the jerking, it is HIGHLY unlikely fuel injector cleaner and/or other fuel system maintenance will help. Have you had the codes read on your vehicle yet?
Old Jul 13, 2017 | 02:12 PM
paulflory's Avatar
engine codes were read as engine missing prior to the spark plug replacement which helped tremendously
Old Jul 13, 2017 | 02:22 PM
shipo's Avatar
Any codes since the spark plugs were replaced? I'm wondering if you may have a coil issue.
Old Jul 13, 2017 | 03:12 PM
paulflory's Avatar
haven't taken it back in to check codes since then. Was trying a few things on my own first
DjSlickSVG
Jan 27, 2014 11:29 PM
katomm
Apr 19, 2013 10:00 AM
norm ops
Apr 22, 2011 10:01 AM
lmeadows52
Apr 22, 2008 02:38 PM
kirk98s
Jun 8, 2007 04:16 PM
