Unable to reprogram key remote
Old Jul 20, 2018 | 04:38 PM
artizhino's Avatar
Default Unable to reprogram key remote
Hi,
I just purchased a used CX-7, but the locksmith said maybe a fuse us bad, I checked the fuses and all are good. What else can I check?
Thank you in advance
Art
Old Jul 22, 2018 | 05:33 AM
How many remotes do you have?
What happens when it is put into programming mode?
Old Jul 22, 2018 | 01:20 PM
artizhino's Avatar
I followed these steps:
Remove key from ignition switch. Close all doors. Open driver's door. Carry out the following procedure within 24 seconds: Turn ignition switch ON and back to LOCK position 3 times. Press and release driver's door courtesy light switch 3 times. Ensure doors lock and unlock. If not, wait 40 seconds and repeat procedure starting with driver's door already open. Press UNLOCK button of each key remote transmitter twice. Ensure doors lock and unlock after each operation. If not, proceed as follows: Press and release driver's door courtesy light switch once. Ensure doors lock and unlock twice. Repeat procedure starting with driver's door already open.
I only have one remote and a regular key, I got the remote from a shop that programs remotes and it was supposed to work, but it didn't.
Is there any other process I need to follow?
THank you
Old Oct 26, 2019 | 09:40 PM
TrickySnake's Avatar
Could it be that it is a locked key? I know keylessremotewarehouse.com sells unlocked ones.
Dackers
Jun 23, 2024 02:03 AM
msalamon
Aug 24, 2012 10:54 PM
1999millenia
Mar 31, 2011 03:06 PM
zerox61
Sep 28, 2010 07:01 PM
kroger
May 28, 2010 08:42 PM
